Custom Feature: Auto Loft
So one day I got sick and tired of creating so many things in order to loft 2 objects and created this new feature:
This feature allows you to loft a surface without having to make another sketch or plane. You can start with 3 things:
LOFT TO POINT:
for this just choose the surface you want and input the X, Y, Z distance from the origin of that sketch. Keep in mind that the coordinates are using the plane that was created on the surface so X is more of length away, Y is width away, and Z is height away.
LOFT TO SQUARE:
The coordinates are the same as before however it is from the center of the new square. Also you can input the length and width of the square that it lofts to.
LOFT TO CIRCLE
Same thing as before the coordinates just go to the center of the circle. Also you can change the set radius of that circle.
Now the add, remove features may not work as well with error messages but that is a bug to figure out for another time.
