Circular pattern causing not to make dimension in drawing
john_narvaez
Member Posts: 7 ✭
I noticed I could not make a dimension of a hole or arc in 2D
However when I moved before the circular pattern I could make a proper dimension of the arc.
I tried everthing found in the web and forum from making another sketch for the origin and using the face pattern.
I did the same sketch in Fusion 360 and could make the dimension in drawing after the circular pattern.
Is there something I missed out. Appreciate any help on this.
Thanks!
Below is the link of the above drawing
https://cad.onshape.com/documents/5f74c0758f7690c479f11ad0/w/94ed50606e996eab2c2ca990/e/adf4625f455e99ebe7fea424
Thanks in advance 😊
