Why does it show in Inch when I have everything set to metric
craigBorrowscraigBorrows Member Posts: 5 ✭✭
If I click I get mm but else it shows in IN.
  • CadeMCadeM Member Posts: 5 EDU
    Try refreshing the page, double-check that your workspace units are saved (click the green check mark), and in your account settings, you can change default units as well. If all fails, contact OnShape support, and I'm sure they will be happy to help.
