My audio on learning modules is suddenly gone.. what do I do
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 998 PRO
    This is probably an issue with your browser or your audio output. Also make sure the video isn't muted or the volume turned all the way down. If other audio (YouTube, etc.) works, try a different browser. Also, it might help to provide a link to the specific learning module you are working on.
  • nate_jake
    nate_jake Member Posts: 7 ✭
    This is probably a browser issue, check if there are any updates pending on your browser.
  • michael3424
    michael3424 Member Posts: 785 ✭✭✭✭
    And check that sound is not turned off in your operating system.
  • gary_smythe
    gary_smythe Member Posts: 2 ✭
    I lost audio on 02. Sketch Entities, Elipses. Polygons audio worked fine. No Audio on 03. Sketch Constrainnts, Using Constraints, etc. Seems like initial topic has a start button and progress bar, but nothing on the topics above. I use Brave browser and swithced to MS Edge, but no joy on audio on same topics. Any suggestions?
