Feature request: Option to make a mesh unselectable
When working with surfaces from 3d scans, Onshape becomes incredibly unresponsive whenever I hover over surfaces because it thinks I want to select vertices. Reducing the amount of polys helps but it's not ideal. Also, please let me know if there is any other way already in Onshape to make this workflow faster.
    You could try using "make transparent" on the mesh and make sure "select transparent geometry" option is unchecked.
