Can't sketch on selected sketch plane
When I select the top surface of an extrusion "Face of Extrude 1" the eclipse I sketch onto it is placed on the top plane instead. If I choose any other face such as bottom, front, back or sides, the sketch is placed there as expected. How can I place a sketch on the top face? Thanks for your help.
https://cad.onshape.com/documents/96b0af2ff41359629ba818ef/w/988c78731746b364b45ff626/e/8f3aa810307560a302a97cc9?renderMode=0&uiState=68f4bd9fa7e2ab380c435357
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 1,002 PRO
    You can only sketch on planar surfaces. The top of that shape is not planar. If you want an ellipse on that top face, you can use the Split tool.
  • Matt_Shields
