Suggestion: Add Shortcut Support for Tools Inside the Quick Menu
mclovin
Member Posts: 2 ✭
I’d like to suggest the ability to assign shortcuts to individual tools within the quick menu, in addition to the regular keybinds.
For example, in the image, pressing S opens the quick menu. With this feature, I could press S C in quick succession to directly activate the Chamfer tool — where S opens the menu and C selects Chamfer.
This would make tool access by shortcut more fluid and if you forgot a shortcut key you can see it right there.
