Routing curve
ryan_jenson
Member Posts: 4 ✭
How would I go about sketching two parallel tubes connected to each other to sweep the same path then a have a twist?
Hey Ryan. Perhaps using a helix for the path would satisfy your task. Something like this. - Scotty
Yes I have seen that example but I would need a non uniform path for the tubes to follow.
There are 3D spline tools available. An image would be helpful to envision what you are attempting. - Scotty
