The Best Onshape Workflow! (Top down? Bottom up? Hybrid?)
MichaelPascoeMichaelPascoe Member Posts: 2,774 PRO
edited October 2025 in General
What is the most beneficial workflow you or your company has found?
We have some amazing users floating around on the forum with incredible experience. I thought it would be cool for new users to see what a professional grade workflow looks like and where to start, what to do. The Learning Pathways teach some must have fundamentals, but they don't go deep into custom features, custom apps, and other neat hybrid workflows that can save tons of time.
I use custom features in almost all of my workflows for Untitled Image CADSharp. And the really automated workflows use custom apps as well. These are things that most newer users don't even know about. Hoping to lower the barrier to entry of quality workflows for people.
Would be useful for users to know which workflow would be the most efficient for the following example cases (or any you come up with):
  • House
  • Car
  • Phone
  • Desk
  • Thermus
  • Headphones
  • Drone
  • Watch
  • Robot arm
  • Coffee machine
  • MichaelPascoeMichaelPascoe Member Posts: 2,774 PRO
    edited October 2025
    Here are some example workflows and concepts to get things rolling:
    Bottom-up design • Build individual part studios separately and assemble them later using mates.
    Top-down design • Drive parts from higher-level references such as layout sketches.
    Hybrid design (top-down + bottom-up) • Integrate both contextual and standalone modeling strategies in one project.
    In-context editing (⚠️Warning to new users, be careful when using In-Context edits. If done incorrectly, you may destabilize time itself opening up a wormhole to another dark dimension causing untold amounts of impossible work for yourself.)
    • Edit a part while referencing surrounding geometry in its assembly context.
    Multi-part studio design • Model several interrelated parts within a single Part Studio.
    Derived parts and geometry • Reuse or reference geometry between studios while maintaining associations.
    Variable studios (shared design parameters) • Store and reuse variables globally across parts, features, and assemblies.
    Layout-driven assemblies • Use 2D layout sketches or construction references to position components.
    Configuration-based modeling • Use configuration tables and logic to define part or assembly variants.
    Template-based modeling • Start new designs from pre-defined part or assembly templates for consistency.
    Custom Feature workflows (FeatureScript) • Extend or automate design logic with user-defined custom features.
    App-driven workflows • For specialized automated tasks.
    Data-driven or API-connected modeling • Use external data sources (e.g. spreadsheets) to control geometry.
    Surface and hybrid solid-surface modeling • Combine surface tools with solids for complex freeform geometry.
    Import and repair workflows • Bring in external CAD models (STEP, Parasolid, etc.) and fix or adapt them.
    For the first 3 products, here are some example workflows that could be an efficient way to do them:
    🏠 House
    • Top-down design
      • Layout sketches and Variable studios (wall height, roof pitch)
      • Multi-part studio for walls, floors, and roof
      • Derived parts / custom features for doors, windows
    🚗 Car
    • Hybrid design (top-down + bottom-up)
      • Master sketch or skeleton for chassis and mounts. Variable studio.
      • A single, static, In-context edit for frame and panels
      • Imported / insert standard content parts (wheels, bolts, engine, etc..)
    📱 Phone
    • Hybrid (Top-down + multi-part studio)
      • Multi-part studio for shell, buttons, and screen
      • Top-down control for overall proportions
      • Derived geometry for PCB and battery
      • A single in-context edit for ports and button alignment
  • Derek_Van_Allen_BDDerek_Van_Allen_BD Member Posts: 720 PRO
    Onshape themselves have put out a decent article discussing many different top-down approaches but for my money the Space Allocation method they show is hands down the best one. At least for my industry. Used properly it's like having a master sketch but with the benefit of stable robust IDs for faces and bodies at your disposal and not limited to the suffocating confines of 2 dimensional geometry. I don't know about the rest of y'all but I produce 3 dimensional objects, and my clients often ask for geometry that cannot be accurately described with 2d projections alone.
    I have modified a bit of the approach from this example though and try to stick to a 1:1 master blob part to part studio rule, and always insert my studios back into the assembly as rigid because the number of parts in my studios is always fluctuating and I need assemblies to adjust dynamically.
  • edward_petrilloedward_petrillo Member Posts: 101 EDU
    We are a FIRST robotics team (293), not a company- there's a pretty big community of other teams like us using OS. I appreciate the opportunity to comment and learn from the experts. A typical robot contains 200 or more parts, half fabricated, half COTS,.multilayered subassemblies, lots of moving parts. Our environment is severely time constrained- 6-8 weeks from a blank canvas to a finished product, with strict external constraints imposed by fabrication rules and game environment. I have seen examples that run the full range of the approaches you' describe. There are many shared libraries and applications that permit bottom-up design by selecting parts, many of them configured, and inserting into an assembly. Some elite teams appear to use SW in-full-blown professional mode and only use OS to share. I strongly prefer a top-down approach.
    The most exciting recent development has been @GregBrown's Published Geometry Feature. The RC car in his YT video maps quite well onto an FRC robot. It enables a bunch of adolescents to work in parallel using a well-constructed skeleton, strictly controlled, as the reference for a top down approach. We're working to implement this workflow in time for our January kickoff.
