How to create a blank ARES Kudo DWG without importing .dwg first
NvO_engineering
Member Posts: 1 PRO
Hi all,
I would like to create a blank DWG in ARES Kudo directly from Onshape without first importing a .dwg file.
Current + menu Only “Create Drawing…” (Onshape drawing) and “Import…”.No “Create ARES Kudo sheet ” or “ARES Kudo” under Applications.
What I have:
- ARES Kudo subscription.
Goal:
- Click + → open blank ARES Kudo DWG (Model + Layout1)
- Add new sheets via New Layout
Question is there a way to:
- Add “ARES Kudo” application to appear in the application menu
- Use FeatureScript to generate a blank DWG/DXF in ARES?
Thanks!
Did you find the answer?
If not, I'm wondering if you'd have to get their Desktop subscription called Ares Commander to do that.
This sounds like an Ares Kudo problem. Have you reached out to them? My experiance with their support team has been good so far.
I think I've asked this question of them a while ago, as it seems the obvious thing to be able to do and the answer was 'no'.
Perhaps have an onshape doc set up with a blank dxf and then copy that as your base?
