Icons on param groups?
EvanReese
I don't think this is currently possible, but want to be wrong. Anyone know if we can add icons for collapsable groups? The Hole feature gets close, but the native icon implementation isn't done via FS imports.
  • _anton
    _anton Member, Onshape Employees Posts: 554 image
    edited November 2025
    Working for me: https://cad.onshape.com/documents/6f2302afa2b4523cc8729522/w/5e1013891277c2ebf88d2930/e/62675c2d3d05f1062f4671fe
    With the caveat that you're not putting an icon on the group but rather on the driving parameter.
  • EvanReese
    Ah, thanks. I don't need a driving parameter for what I'm doing though. Any workarounds?
  • Derek_Van_Allen_BD
    Derek_Van_Allen_BD Member Posts: 1,162 PRO
    Can you drive with an empty static parameter to trick the UI?
  • _anton
    Read-only string parameter?
  • EvanReese
    I actually tried a read-only string param after your first reply, and it seems they can neither take an icon nor be the driving param.
    FeatureScript 2815;
    import(path : "onshape/std/common.fs", version : "2815.0");
    ICON::import(path : "473f913b444c0e44b4206c1a", version : "ea421e8e47ec7c2998ac44e9");
    annotation { "Feature Type Name" : "My Feature", "Feature Type Description" : "" }
    export const myFeature = defineFeature(function(context is Context, id is Id, definition is map)
        precondition
            annotation { "Name" : "My String", "Icon" : ICON::BLOB_DATA, "UIHint" : UIHint.READ_ONLY }
            definition.myString is string;
            annotation { "Group Name" : "Group", "Driving Parameter" : "myString", "Collapsed By Default" : false }
                annotation { "Name" : "My Boolean" }
                definition.myBoolean is boolean;
                annotation { "Name" : "My String" }
            // Define the function's action
