Wrap a solid part around a cylinder then boolean remove it
Hi guys, I'm new to cad, so excuse if the question is a bit dumb, but for the life of me I cannot find an answer.
I'm trying to remove a part that would wrap around a cylinder.
I have designed a (flat) part, that I want to wrap around a cylinder, than remove it from the cylinder.
What I have tried:
- Designing flat part, on a plane, than wrap and remove ( it is super time consuming and not easy for complex part + It does not allow for a chanfer to be added in onder for the part to release easily)
- Designing the part then mate them in assembly and then edit in context to boolean substract ( cannot wrap the part)
Do you have any idea to make this possible?
Your document share did not work.
Not a wrap and a little bit of work done with splitting the part to remove with a cylindrical surface or surfaces. Perhaps a method might be able to use.. - Scotty
https://cad.onshape.com/documents/b9e1074ba31daa4f6625ac9c/w/49184828a7d37eddad00bad1/e/bec7b78bfa09d52ef08aa824
Hey Frederic. Not sure what you mean by remove, but check out the updated document I posted and let me know if I'm on the right track - Scotty
