Inserting bounding box dimensions into BOM
I found the feature script for "Aligned Bounding Box" which creates a variables table like the one shown below. How do I then get these values inserted into a BOM?
Name
Variable type
Value
Description
box1_X
Unspecified
169.941 in
box1_Y
Unspecified
5.5 in
box1_Z
Unspecified
11.25 in
  • eca_elioac
    eca_elioac Member Posts: 19 ✭✭
    @pete_mathis
    You can't… Those data from your custom table (featurescript) live only inside the partstudio, I don't think you can bring them into the assembly/BOM
  • Caden_Armstrong
    Caden_Armstrong Member Posts: 468 PRO
    you can copy and modify the feature and have the feature set a custom property in your parts, and then add that custom property to your BOM.
    It would require a small bit of featurescript knowledge to achieve
