Failed to extrude, check input for two identical parts and extrudes
Here is a link to my document: https://cad.onshape.com/documents/b0d4b50641134a7bdb3b434f/w/acec1f7448d550d9c57c8e07/e/d518e41c58a4313287b65722?renderMode=0&uiState=694858e7dcbd655c37d5a848
I was trying to make a paint brush stand. As you seen in the file, sketch 5 splits the top surface in to two parts. Although they are equall, the following uses of GridExtrude feature script do not act how they should - the first one works, and the second displays an error. The error stays regardless of grid size (in grid extrude), whether they remove or add material, and other things. Initially I planned to have 2 different halves, but as you can see this does not even work with identical halves.
