How do I rotate the sheet 90° in a drawing?
mi_sg
Member Posts: 2 ✭
Do to the shape of some parts, sometimes it appropriate to use a sheet in vertical (portrait) mode.
Is there a way to do this with onshape?
You would need to make your own drawing template. OS has some references to start from for boarder format then you'll need to copy your own title block.
