Configurations API endpoint
Hi All,
I have a Partstudio that has several configurations (A, B, C, D, etc…).
When I use the below endpoint.
https://cad.onshape.com/api/v13/elements/d/{did}/w/{wid}/e/{eid}/configuration
It gives me all the available configurations which I can use to construct my next API calls, however, it always defaults to Configuration A, even though I got Configuration B loaded in my current workspace.
Is there a way to know which configuration is currently loaded in the workspace? Because I'm trying to avoid asking my user which configuration do they want to use in the app when it's already obvious that they want to load whatever configuration they got currently loaded on the workspace.
Thanks in advance
https://onshape-public.github.io/docs/app-dev/extensions/
To get the users current configuration, you need to add {$configuration} to your action URL in your app.www.smartbenchsoftware.com --- Renaissance --- Kestrel -- SmartLink
Experts in Onshape Automation - Custom Features and Integrated Applications1 -
@Caden_Armstrong Solid!.. thanks sir!
