What the correct ${............} convention to be able to export the name of a configuration?
paul_masserpaul_masser Member Posts: 19 PRO
I want to set an export rule with this to uniquely name each config on export.
Thanks in advance,
Paul
  • paul_masserpaul_masser Member Posts: 19 PRO
    I just worked out what was wrong. I'd named the configs in the configured properties tab and not changed the configuration to apply them to the second part that I'm exporting…
