Fillelt works on one part of the model, but doesnt in its exact copy but mirrored.
lukas_vitek
lukas_vitek Member Posts: 4 ✭
Hi,
im making an fpv frame but i cant forf some reason fillet this.
I filleted the other side with the same settings just fine. Even tried to turn off other fillets.
Please help.
  • martin_kopplow
    If it is mirrored: Roll back and make the fillet before the mirror. Easy. :0)
  • lukas_vitek
    Its not mirrored, somehow its the same part but mirroring doesnt work, it wont fillet even whet i select only the part that doesnt work.
  • CADNurd
    CADNurd Member Posts: 166 ✭✭
    It could be caused by some very small difference. If you share your file, maybe someone can identify the issue.
