Bug Report? Or By Design?
I'm surprised I haven't run into this before, but a very simple extrude just failed for me. I just have a rectangle fully enclosing a shape where one point of a corner rectangle is on a circle. Here is a link:
https://cad.onshape.com/documents/18a3695189ac355ff7b3a6a6/w/a48d7b7c0b1931006843cab5/e/20d5639ea63f9c9206d93d34
I'm just trying to extrude the part of the larger rectangle that surrounds the other two shapes. Is there a reason this can't work. It seems mathematically possible. If this is a bug, how does one report such things?
Here is a script to reproduce the issue:
1) Make a center-point circle with a point not on the origin that is sized to touch / be coincident with the origin.
2) Make a corner rectangle with the first point on the origin and the second point placed so that the rectangle does not intersect the circle.
3) Make a larger rectangle not connected or touching any of this.
4) Try to extrude the space inside the larger rectangle, but outside (not including) the smaller rectangle or the circle.
RESULT: Red failure to generate with no info why.
Here is more info about this limitation:
https://forum.onshape.com/discussion/23348/why-is-this-non-manifold-no-it-isnt-whats-the-quickest-workaround..TLDR: Its called non-manifold geometry. Two bodies can't share a vertex that would create 0 distance of some kind.
▚▞▚▞▚▞▚▞▚1
▚▞▚▞▚▞▚▞▚1
