Is there any way to auto dimension points in sketches?
I have a sketch by tracing a picture, is there any way (or script or way to make a script) to auto dimension each point (as in start and end points of lines as well as points from splines) to for example the origin?
It´d be optimal, if there was a option to choose a reference point as well the possibility to choose multiple points from the same sketch and put horizontal and vertical dimensions between them.
I have looked through the script library, but couldnt find anything pre-made nor did I find anything in the scripts available online…
It should also be said, that I have little to none programming experience apart from learning C at uni…
Kind regards,
Peter Lustig
