What's wrong with this Loft?
vedran_alajbegovićvedran_alajbegović Member Posts: 12 ✭✭
I believe the image asks question itself. How can i make this loft between square and a circle?
  • MichaelPascoeMichaelPascoe Member Posts: 2,814 PRO
    In your circle sketch, use the split feature to split the edges of the circle into 4 sections. Then edit your loft and add "Connections" from each corner of your rectangle to each split vertex in your circle sketch.
    RENDERCAD
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 943 PRO
    It's helpful for the two profiles of a loft to have the same number of entities, so you can use Connections. In this case, just drawing a construction square on the circle is enough.
  • vedran_alajbegovićvedran_alajbegović Member Posts: 12 ✭✭
    thnx guys
