dimension arrows only showing internal - new user
Hi sorry if this question has been aske before but, when using sketches and applying the dimensions my dimension tool only seems to create arrows internally ←10—> not > ←-10.
I'm pretty sure it did this when I started the tutorials etc. but I can't seem to get it to work what am I missing?
Do the arrow locations have any affect in a sketch? You can drag the dim anywhere you want if in the way. Maybe you are confusing a sketch and the formal drawing functionality which has more controls.
-S
Susanna, when I first started I encountered this issue as well. I believe all you need to do is grab the arrow and move it into the direction you want it. It will move along the selected plane and change from (-) to (+) or vice versa. Hope this helps.
Also, if this does't fix the issue, please post a screenshot. It might prompt us what's going on.
Thanks for your help I'll try to find the project I was working on.
it was in the sketch function and I was finding that with the internal arrows the dimention, number, was being over written by the arrows ← → and it would have been clearer if I could have convinced it to show the dimention as →| |←
I did try to move the 'Dim' every which way to no avail.
I'm going to try to design a simple storage box for my garden using wooden decking and rails and then produce printed plans as a learning excercise.
