Frame trim
kevin_mason558
Member Posts: 70 PRO
I have a grid of frames
Without having to draw each segment separately I thought I could use the frame trim.
this won’t work as it wont remove the intersections and keep both sides
sketch and extrude then won’t allow the parts to fill into a cut list as it can’t determine the ends.
Is there an easier or quicker way to do this other than separately adding individual frame sections?
You can do multi frame trimming with Frame Trim+ using the body trim option.
.◉ RENDERCAD - Photorealistic product rendering.◉ CADSharp - Professional CAD + software consulting.
▚▞▚▞▚▞▚▞▚0
