Can I take a part photo and bring it into Onshape?
I made a pattern on the dash of my project car and I need to send it to have it water jetted. It's just flat.
Yes, you can. In the very bottom left of your document's screen is the + sign that you used to create a part studio, etc. Also there is the option to Import which you can use to bring in an image. After the import it will be located in a new tab along with part, assembly, drawing, etc. tabs. Within a sketch you can insert the image. The Insert Image tool is located along with the other tools at the top of your document. - Scotty
