Feature Request - Opening different studio to work on simultaneously
WRegnaudWRegnaud Member Posts: 6 PRO
Let's say I have a variable studio that is inserted into all part studios and assemblies. This variable studio drives multiple parameters across the project. having the possibility to open the variable studio at the same time as another studio would help to iterate the design more rapidly. A work around at the moment is to open multiple instances of Onshape in the browser. The drawback here is the amount of RAM required to operate multiple tabs at the same time.
Having the possibility to open multiple tabs of different studios in the same instance of Onhsape could prevent the back and forth between studios and reduce the ressources draw on the computer hardware.
Thougths?
  • S1monS1mon Member Posts: 4,062 PRO
    If the variable studio is part of the same document, and the part/assembly tabs have it inserted, you can open the variable side bar and edit the variable values while looking at the part studio or assembly. It's also very possible to have multiple browser tabs or windows with views into the same document. Generally this isn't a huge memory issue.
