Can't figure out CANNOT_RESOLVE_ENTITIES from opBoolean
mike_holczer
mike_holczer Member Posts: 6 ✭
I've been going through the FeatureScript Fundamentals course in the learning system, and I'm on the final exercise. I'm getting a CANNOT_RESOLVE_ENTITIES from a opBoolean call, and I can't figure out what going wrong. I've more than triple checked my code against what's provided in the instructions, and I've added debug calls for the both the tool and target queries being passed to opBoolean and they both are finding a solid body. It would be great if someone could take look and see if you can spot what I'm doing wrong.
My document is https://cad.onshape.com/documents/a54f7c681817ca14f0810e10/w/7df64ab373a51dd1933f9e7f/e/19616971d3925d5cbcf6d147. Error is on line 80 of the Milk Crate Lattice FeatureStudio.
Thank you in advance for any help you can provide.
  • EvanReese
    It seems like you figured it out?
  • bryan_kohn
    bryan_kohn Member Posts: 2 ✭
    When performing booleans, only the first bodies name is retained. If you add B to A, the new part is A. Even if you give it a new name, it will still be A. Try the first body mentioned in your opBoolean, and then see if that Enitity can be found.
