How to drive Surface (Face) names via Configuration?
hoolito
hoolito Member Posts: 41 PRO
edited April 2 in Community Support
I am looking for a way to explicitly name a Surface entity (Face) based on the active Configuration.
The Workflow:
Sketch -> Extrude -> Fillet (Base geometry).
Offset Surface (Zero offset): I extract a specific face from the solid to use as a master surface for downstream Derives.
The Goal: I need the Name of this resulting Surface/Face to change based on my Configuration Table (e.g., Surface_Concept_A_(width), Surface_Concept_B_(width)).
https://cad.onshape.com/documents/3b69eb36b4238a18f4d8bca1/w/465d81698e36d892a6ea7b2a/e/9d63fc2be68d94bde1b15442
Thanks for any help!
