Kiri Moto which machine?
scott_caskey
scott_caskey Member Posts: 56 PRO
Which machine should I pick for Kirimoto in setup when I have a Precision Mathews PM30 converted to CNC using a Centroid ACORN control board running Centroid CNC12 software?
  • eric_schimelpfenig
    eric_schimelpfenig Member Posts: 97 EDU
    Doesn't look like there's a machine in there that has that specific flavor of G code. Centrioid is pretty much a Fanuc G code flavor.
    You might be able to make Linux CNC work… My guess is that it's going to be the closest one.
    What is it you're trying to machine?
  • scott_caskey
    Eric,
    Thanks for the input. Machine tools are a necessary evil to me. I use the mill to make cutouts and drill hole patterns in electronic enclosures mostly.
    I was using the CAM feature in Fusion 360 but apparently, they won't support any OS older than Windows 11 now so no worky. Looks like I may have to get a windows 11 machine just to run F360 if I can't get the kirimoto to give me what I need. It seemed lacking in a lot of areas as I didn't see anywhere for you to configure cutting speeds, tool diameters, offsets, etc., but then again, I just opened it a couple of hours ago.
  • Ste_Wilson
    Ste_Wilson Member Posts: 681 EDU
    The kiri Moto forums might provide more help.
    https://forum.grid.space/
