Part appearance properties
graham_lock
graham_lock Member Posts: 277 PRO
Hi all,
I have scripts which set properties on the parts they generate to identify part types.
I have a separate feature which uses those properties to set part colours by part type.
it seems that if I have already manually set appearance on a part that it takes precedence over the script. I’m not sure how to correctly reset any manual appearance edits made, I’ve tried resetting properties but that doesn’t work.
Any help appreciated.
Thank you.
  • Matt_Shields
    Matt_Shields Member, Onshape Employees Posts: 1,002 PRO
    Select the part or parts, right-click and select properties. Click reset all. That will allow custom features to change part names or colors.
  • Matt_Shields
  • graham_lock
    Thank you.
