how do i read an answer to a question
paul_mulvey
Member Posts: 5 ✭✭
It will appear right here 😉
But as a new member there will be a delay (a few hours, maybe half a day?) until your question is posted for others to see, so be patient.
Welcome. There's a lot to learn but you'll figure it out. Go through the intro lessons in the learning center, and use the help files and Google if you're stuck. I've only been using Onshape a few months, but I get stuck a lot less than I used to. Well, less any way!
2
