Plastic Threads - American Flat 6 - Odd behavior
habib_salim
habib_salim Member Posts: 39 PRO
Hello,
I am designing a part that will be made in steel. I wanted to get a 3D printed version as a sanity check but the threads are not coming out OK.
I was happy to see this feature script but it is showing some odd behavior. https://cad.onshape.com/documents/6c8e8157358c1a0fdb12f813/w/b16f42265b9d06e084ddd654/e/ac04848db602c96cc5661837
In KA-Drain_V8 Parts, I have a Drainpipe. on the outside wall, there are two surfaces - a 39mm OD and a 37mm OD. Both threaded surfaces
When I add threading the 39mm surface, it weirdly adds a surface below it. Am I doing something wrong?
I did not have this issue using Onshape's cosmetic threads not with the Thread Creator tool (but with that, the threads did not work)
