My Feature Script 'Spring Maker' stopped working
Otto_DeRuntz
Otto_DeRuntz Member Posts: 39 PRO
Not sure when this happened but all the springs, made using a feature script, we named 'Spring Maker V2.1', are failing. If I go back to any earlier release or version the springs generate fine. The error I get is 'Spring Maker V2.1 did not generate properly; Could not create a valid swept body, check input.'
  • ry_gb
    ry_gb Member, csevp, pcbaevp Posts: 273 PRO
    Maybe go back to referencing an older version of the standard library?
    Ramon Yip | glassboard.com
  • Otto_DeRuntz
    The script has always worked. It's been improved to add more needed functionality. Onshape did something to break it.
  • wille_j
    wille_j Member Posts: 148 ✭✭✭
    Link and we can help debug? 😃
  • Otto_DeRuntz
    The last version regenerated fine, so I restored it too main and it broke.
  • Otto_DeRuntz
    How do I link my file?
  • Otto_DeRuntz
    I believe this is it, My latest version is V2.1
    https://cad.onshape.com/documents/f46edbce21e8fdfbd1376ace/v/f832e646bc4cc10a836ce4db/e/b25f3674c907262eac450d9f?showReturnToWorkspaceLink=true
  • wille_j
    Seems to be a private document, I can't access that link.
  • ry_gb
    What I mean is this:
    Try to change the number back a previous version of the standard library.
  • Otto_DeRuntz
    The tool was updated and refined by a coop we had a year ago, I am now trying to understand the tool better myself.
    My feature script was built using Feature script 2473. I don't have any earlier versions of feature script. What I don't understand is why the previous versions generate fine from the same script, 2473, but when I switch to the 'Main' version the part won't generate.
    The error that I get is "Could not create a valid swept body, check input." . I don't know how to understand where the failing feature is in the script and how to debug or fix it.
  • Otto_DeRuntz
    How can I share my document so that others can see it?
  • Otto_DeRuntz
    edited June 17
    I made my Spring Maker Tool Public, so I think anyone interested can open it.
    SpringMaker | Current Spring Maker
  • jnewth
    @Otto_DeRuntz At least the broken instance in your shared doc is fixed by using opSweep the way you used to use opSweep: dont specify a lockFaces. It's an optional parameter, so you dont have to, and Im not really sure what you are trying to achieve by including it. At line ~1206::
                opSweep(context, sweepId, {
                            "profiles" : qSketchRegion(profileSketchId),
                            "path" : qCreatedBy(helixId, EntityType.EDGE),
                            //"lockFaces" : qSketchRegion(profileSketchId)
  • Otto_DeRuntz
    That fixed it! Thanks
    I did not write or update the script, so I still need to learn and understand better.
    But a BIG Thank YOU
  • jnewth
    Ah - all good. A helpful place to start is the FeatureScript Notice area. When a feature breaks in a part studio, it usually reports where (in code) it broke, which is very important when troubleshooting custom features. Click the
    { ✔️ } in the upper right corner of the top row and you can look at a 'callstack' of the failure. That's how I found which particular operation (the opSweep) had failed. From there I just looked at the difference between the two versions.
  • jnewth
    One last thing: if youre just getting in to FS (welcome! the water is warm but unusually full of sharks!) check out theonsherpa.com
    Evan will get you rolling for sure. And his videos are great (I was in one!)
  • martin_kopplow
