Part mirroring generating too many sheet metal bends
HMoit
HMoit Member Posts: 5 ✭
First time Onshape user (with very limited CAD experience) here encountering a problem.
I've modelled a speaker stand which surprisingly turned out exactly how I envisioned it. However when I enter the 'sheet metal table and flat view' there are more bends than there ought to be.
I designed one foot with a slot running the length and 2 bends and used the mirror tool to create the remaining 3. The original leg generates 2 bends in the sheet metal table as expected but the mirrored legs generate 4 each for a total of 14 bends when there should only be 8. Any idea what's causing this? I've attached the link to the model.
Any help much appreciated. Thanks in advance.
