Is the MateConnector.fs code the only way to do in-context inference in a script?
joshtargo
Member Posts: 695 EDU
The only way I've ever been able to use inferred MC's as inputs while modeling in-context is with this exact code, even the requirement of naming the function "mateConnector".
Do I need to use this exact code as the basis for these types of scripts, or is there a more universal/normal way to do it?
FeatureScript 2960;
import(path : "onshape/std/common.fs", version : "2960.0");
export import(path : "onshape/std/origincreationtype.gen.fs", version : "2960.0");
export import(path : "onshape/std/entityinferencetype.gen.fs", version : "2960.0");
annotation {
"Feature Type Name" : "Context MC Test",
"Feature Type Description" : "Minimal in-context mate connector from a single entity pick."
export const mateConnector = defineFeature(function(context is Context, id is Id, definition is map)
precondition
annotation { "Name" : "Origin type", "UIHint" : UIHint.ALWAYS_HIDDEN }
definition.originType is OriginCreationType;
annotation { "UIHint" : UIHint.ALWAYS_HIDDEN }
definition.entityInferenceType is EntityInferenceType;
definition.secondaryOriginQuery is Query;
definition.originAdditionalQuery is Query;
annotation { "Name" : "Specify normal", "UIHint" : UIHint.ALWAYS_HIDDEN }
definition.specifyNormal is boolean;
annotation { "Name" : "Normal x", "UIHint" : UIHint.ALWAYS_HIDDEN }
isReal(definition.nx, { (unitless) : [ -1, 1, 1 ] } as RealBoundSpec);
annotation { "Name" : "Normal y", "UIHint" : UIHint.ALWAYS_HIDDEN }
isReal(definition.ny, { (unitless) : [ -1, 1, 1 ] } as RealBoundSpec);
annotation { "Name" : "Normal z", "UIHint" : UIHint.ALWAYS_HIDDEN }
isReal(definition.nz, { (unitless) : [ -1, 1, 1 ] } as RealBoundSpec);
annotation { "Name" : "Location",
"Filter" : (EntityType.EDGE || EntityType.VERTEX || EntityType.FACE) && AllowMeshGeometry.YES,
"MaxNumberOfPicks" : 1 }
definition.originQuery is Query;
const csys = evMateConnectorCoordSystem(context, definition);
opMateConnector(context, id + "mc1", {
"owner" : qNothing(),
"coordSystem" : csys
"originType" : OriginCreationType.ON_ENTITY,
"entityInferenceType" : EntityInferenceType.POINT,
"secondaryOriginQuery" : qNothing(),
"originAdditionalQuery" : qNothing(),
"specifyNormal" : false,
"nx" : 0.0,
"ny" : 0.0,
"nz" : 0.0
