Making circular pattern with a part and the circular parts can be given new properties?
Hello
I make elektric cables for a big machine. Now I have one terminal box on the left side and one terminal box on the right side. The cables are the same on both sides, but the properties should be different. It is not mirrored but done in circular pattern. Is there any possibility to make a circular pattern and the parts have not the same properties?
I assume you're talking about a circular pattern in an assembly, in which case, no. The way would be to make the pattern in a part studio where you can assign different properties to the different bodies, or set up a configuration of them at the source part studio where you configure the properties. Those can be inserted into the assembly in each config to get the properties you need.
