How's AI for feature scripts working for you?
I am trying to use Gemini for feature script creation and it has not been awesome. I have tried up to 5 iterations where I feed OnShape errors back into Gemini to fix, and not been successful. Someone told me he had to run 40 iterations! Is this other people's experience? How many debug iterations do you run?
I've been using Claude and it's awesome.
@Kevin_Pasko it's been pretty good. Are you using a Gemini chat? I tried that when I was just getting into it and kept having issues where it would essentially try to re-write the code completely with each reply instead of editing it, which kept reintroducing things that had been fixed. Using one that's dedicated for code should work a lot better, like Claude Code or ChatGPT Codex. It's even better now with the Onshape MCP letting it connect directly with Onshape to update the code, and test things out.
Also, the higher level models have been working best for me. I don’t use Gemini much except when I’m just doing a regular web search and I get the “AI results”. Those have been sucking less than they used to. I’m coding with ChatGPT Sol High or Extra High.
I use either Claude chat or Claude code and it's been very good. I've made highly complex features, and improved them with generally little trouble.
A few things that can help:
Use a mode where it can refer to the standard library document.
Use it to create an app spec before coding anything.
Have it create the UI first, this is where it needs the most help from a human.
Give it coding rules you want, such as formatting, how much it chops the code into sub functions, etc.
1
