Wildly varying regen times with instantiate
I've got a feature that instantiates configured geometry from Part Studios in previous Version of the same doc. Three addInstance calls into one instantiator, then a single instantiate.
Regen times swing by roughly 8x and I haven't been able to find a repeatable pattern.
What I'm seeing
Regen lands at either ~200ms or ~25ms, with very little in between. The same feature producing identical geometry will sit at one number or the other depending on what I did immediately before, and I can't predict which.
Some things that seem to matter, though none of them hold consistently:
- Scrubbing the numeric inputs around and returning to a value often drops the time to the low number, but not always.
- Committing the feature and reopening tends to help, but not always.
- Suppressing and unsuppressing seems to reliably drop it to ~25ms without touching any input.
That last one is the part I find strangest — same parameters, nothing edited, and the cost disappears. So whatever the expensive work is, the re-entry path skips it and the first-touch path doesn't.
There's clearly some caching involved, but I've had trouble characterizing its scope. It isn't global across documents — a set of values that's fast in one document costs full price in a fresh one. Within a document it's shared between multiple instances of the feature. Beyond that I've had results that contradict each other.
What I've ruled out
- Not my authoring workspace. Same behavior in a clean document with the feature inserted normally.
- Not the dialog. Times are the same whether the dialog is open or committed.
- Not document reload or tab switching. Neither changes anything.
Questions
- Is cost like this expected for
instantiateagainst a configured source studio, or does 200ms suggest something inefficient on my end? - What actually gets cached, and at what scope? I'd like to understand what a real user experiences versus what I see while iterating.
- Would
opMergeContextsbehave differently, or is the cost in regenerating the source studio at the configuration — in which case the transfer mechanism wouldn't matter? - Anything I can do from the feature side to reduce first-hit cost?
