Help with Fillet
j_nelson
j_nelson Member Posts: 2 ✭
https://cad.onshape.com/documents/0335d2f5370fc0cb60e5cedf/w/663084dfd78627ce5d9b3f71/e/804c66af637e2dbedca0e1bd?renderMode=0&uiState=6aa6a23b27d36cf2d8751a1c
Hello, I'm currently following a surfacing tutorial for Solidworks but doing it in Onshape and so far I've managed to figure out most issues I've come across translating the techniques myself. However, in this tutorial the teacher was able to use the Solidworks fillet tool to fillet the edge on the rear of the tool which goes from an angle between the two adjacent faces to tangency so essentially needs to fade out. Is this possible to do using the Onshape fillet tool. For me it doesn't want to work, also tried variable fillet without success.
I know i could solve this by trimming on either side of this edge and lofting between the surfaces but I want to know if Onshape can do the speedy/lazy way.
  • ian_whaples807
    ian_whaples807 Member Posts: 10 ✭
    it looks like the loft you used has come weird continuity, making things on the back generate strange. I fixed this by selecting the actual edges for the loft instead of the curve and instead of a fillet, I used a face blend.
    https://cad.onshape.com/documents/a913f1948d6df8b858de4c2a/w/dccd56ea206d08b11bf97c8f/e/50c4ea418ece2029bc2deb0b?renderMode=0&uiState=6ad93c48fc0ccf414d866419
