Make all parts in part studio to Not Rev Mge, Exclude from BOMs, and Tessellation to Coarse
Erci_Cheung
Erci_Cheung Member Posts: 15 PRO
Is there a way to either Featurescript or something to automate the process of making all the parts in Part Studio to "Not revision managed" and "Exclude from all BOMs" and make the Tessellation quality to Coarse?
I do this often and it would be nice to have it down with 1 click.
  • wille_j
    wille_j Member Posts: 149 ✭✭✭
    Certainly! Research or tell your favorite LLM to research setProperty in FeatureScript :) Quick mental map it would be ~10 lines of code.
  • Chris_Tilton
    Chris_Tilton Member Posts: 12 EDU
    You can set the first two with this custom feature: Property/Attribute (Pascoe) | Example studio. Not sure about the tessellation quality though but I would guess that that's outside of the realm of FS.
    Technical Services Engineer, Onshape
  • wille_j
    Tessellation is a property and can also be set with setProperty. And that FeatureScript certainly works too, but it would mean you have to type in the custom property id every time you use it. Definitely not a 1 click solution 😊
  • Chris_Tilton
    Good catch!
  • Erci_Cheung
    Well, AI did the trick, thanks all for the input.
