Hole Pattern FeatureScript
john_gurosik
john_gurosik Member Posts: 4 PRO
Here is a featurescript that can be used to create equally spaced holes using a sketch as a reference. User can select a square/rectangle or even a series of lines (circle, polygon or polyline for example) The featurescript will create equally spaced holes or the user can define the desired spacing. You can also select which solids it gets merged with and apply a second set of holes with the same center point to a second group of solids. In addition to the standard hole options built into Onshape you can also make the holes slotted if desired.
https://cad.onshape.com/documents/838896df8f4280746a72d90d/w/d32b2361acd3f472f36c2398/e/cf3c48e587de44108f8d2b28
