Why Does "Grouping" Of Lines On Drawings Occur Based on Views?
When in a drawing tab and utilizing the sketch tools it is possible to "bind" drawn lines and borders to part views. This appears to occur when a line is sketched through the binding box of a part view. It will not only group the view to the line drawn through it but also to any line the drawn line has a constraint with. This creates a problem when the view is moved, copied or deleted as all of these "grouped" entities will follow the same operation.
In limited testing, if the sketch is made first and the view is placed over it, everything is fine. If the sketch is made first and then moved over a drawing view, everything is fine.
Is there any reason for this to happen? Is there any way to unbind or degroup these sketches from the part views once this occurs?
