Midplane Offset – Custom FeatureScript for Onshape
XionXperience
XionXperience Member Posts: 2 ✭
Hi everyone!
I'd like to share a custom FeatureScript I've developed called Midplane Offset.
I created this feature because I wanted a quicker and more flexible way to create a construction plane between two parallel faces, with the option to adjust its position without creating additional offset plane features.
Features
  • Automatic Midplane – Creates a construction plane exactly between two parallel faces or planes.
  • Adjustable Offset – Offset the plane from its midpoint by a specified distance.
  • Interactive Drag Manipulator – Adjust the offset directly in the 3D workspace.
  • Reverse Direction – Easily switch the offset direction.
  • Automatic Plane Sizing – Automatically adjusts the visible plane dimensions based on the model geometry.
  • Manual Plane Sizing – Optionally define a custom plane size.
  • Fully Parametric – Automatically updates when the selected geometry changes.
How It Works
Simply select two parallel planar faces or planes, enter your desired offset or drag the arrow directly in the 3D workspace, and you're done!
Try It Out!
Midplane Offset – Onshape FeatureScript
Feel free to add it to your custom feature toolbar and use it in your own projects.
This is my first public custom FeatureScript, so I'd really appreciate any feedback, suggestions, or ideas for improvements!
Thanks for checking it out!
Developed by XionXperience
Engineering, CAD & 3D Printing
https://xionxperience.com
