loft command gone wrong...
hey
i have 2 profiles to make loft and for some reason they connect wrong . lost all ideas of how to fix it , any hints what makes them twist at certain point ?
https://cad.onshape.com/documents/4b751f97645b5fb02e05fb20/w/6c6b5d5c72df1ef22736100c/e/2b3b17e1902c20f49149a33b
  • robert_scott_jr_
    robert_scott_jr_ Member Posts: 948 ✭✭✭
    Hello. Here is the problem:
    One possibility to fix it is to move the face of the flange towards the shell (.1mm works) and then do a Boolean to make them one part. Another method would be to add an addition inner offset to the shape you created in sketch 2 and include that region in the extrude. - Scotty
  • martin_k_leichtwerk
    martin_k_leichtwerk Member Posts: 4 PRO
    … or you could use the "Replace Face" Feature and replace the inner face of the flange with the outer face of the shell BEFORE you try any booleans. That should be more reliable with later edits than making an offset based on a guess.
