Create negative part
dimitrios_baltzis
Member Posts: 5 ✭
I want to create a negative part with the orange part as a cavity that will be used as a formwork for concrete casting. I tied to use the Bollean subtract but the process result only includes the blue part.
Is there a way that I can create the cavity?
There is always a way :)
Can you please clarify. The Boolean operation resulted in the blue part, correct? With a cavity. Isn't that the negative that you want?
