DXF Import or Export
For the products that my company makes, we laser etch artwork onto a cylindrical component. In the past, someone would sketch all of the artwork in solidworks. This artwork would be exported as a DXF to load into the machine and wrapped around the part in 3D for the drawing for QC checks.
Different variants of the product have different artwork requirements, so there was a lot of manual work when ever this needed to change.
It seems like a good candidate for a FeatureScript, but I've been struggling with the DXF part.
My first attempt was use the MCP to write a feature that would take a DXF file and then wrap it onto the part. This sort of worked, but the file had to be renamed as a TXT file and there was a size limit since the native Insert DXF tool doesn't seem to be accessible. Also this still required the generation of the DXF in a separate program.
The second attempt was to use FeatureScript to generate all the artwork as a sketch directly in OnShape. This seemed to work really well to create the 3D file, but there doesn't seem to be any way to export the flat sketch as a DXF to program the laser.
Any thoughts of other approaches? Or something I'm missing?
Thanks for the support.
