Why Onshape Thinks Two Separate Faces As One?
martin_diamond
Member Posts: 2 ✭
I have two separate faces. Why, when I revolve the other face, the other disappears? I can see it returning to the sketch, but I cannot select it anymore.
@martin_diamond I guess the sketch is just hidden. Onshape hides sketches when you use them in a feature. Is the sketch greyed out? If yes, just hover and klick on the eye to the right.5
@martin_diamond , I also think you have created both profile in same sketch. After using revolve operation consisted sketch go in hidden mode. therefore user has to on the visibility of sketch by right clicking on sketch show operation or place mouse curser on sketch, eye icon will appear in which show sketch option will highlight. User can show sketch by clicking on eye icon as suggested by @florian . Kindly refer below video for more detail
5
@ martin_diamond , Is that the two face are created using a single sketch command? if so then as florian told it may be hidden.
5 -
Ok, Thanks! I found it!
