How to insure circumscribed polygon sides are vertical (or horizontal)?
matt_manuel
Member Posts: 1 ✭
I want to make a hexagon where the left and right edges are vertical (90 degrees.) I can't find how to constrain them and I end up doing it "by eye" which isn't confidence inspiring.
Hi Matt,
After sketching the polygon, select the edge you wish to be vertical and click the vertical constraint.
/ScottScott Harris / Onshape, Inc.0 -
@matt_manuel ,You have to check by show constrains option. If Horizontal / Vertical constraint symbol is not there then you have to select one edge and give Horizontal / Vertical constraint. Kindly refer below video for more detail.
