Can't Download Locally
julien_bélanger
Member Posts: 2 ✭
I'm using the free version of Onshape and I can't export anything that I've done, in fact, there's no export button nowhere. Is this normal? I can Import thought.
If you right click on a Part Studio or Assembly tab with parts in it, you will see an Export option, from where you can Download directly, store the export as a tab and download, or simply store the export as a tab.julien_bélanger said:I'm using the free version of Onshape and I can't export anything that I've done, in fact, there's no export button nowhere. Is this normal? I can Import thought.
5
5 -
It's probably just me, but "download" always gives me pause. My first thought is that it should be called "upload" until I remember that we actually are downloading the file from the web to our local drive. Putting DropBox in the mix makes me a bit dizzy.0
Thanks a lot, work for me now!0
