Mate Limits Imperial
ryan_thiessen999
ryan_thiessen999 Posts: 12
edited March 2016 in Community Support
I don't know if this is a bug, or a setting that I am missing.
I am working on this project:
https://cad.onshape.com/documents/56dd8fdee4b0a5e7b6f8f708/w/a85ad66e969e3bf43e2c9144/e/d4d76ed1ff1f5bfaa1f78bdf
and I think I have everything set up in metric, but when I try to add mate limits to the slider in the linear translator assembly they are showing in the workspace in inches.
Thoughts?
  • That's exactly what I was missing.  Thanks a bunch viru!
    @ryan_thiessen999 , I think this is happening because you have selected your assembly unit in inch in-place of mm and other document unit in mm. Kindly refer below image of your assembly work-space unit. You can change your default length unit into mm.After that all dimension will come in metric unit.
