How can i match the axis
heiko_pressel
Member Posts: 9 ✭
You just need to mate something (anything) to the origin. Use the Fastened mate to choose a mate connector that will be at the origin, then click the origin. You can then use the flip/rotate mate command to orient things whichever way you want.6
Thanks for your answer. after solving a diffrent problem your hint works fine
Glad to hear it.0
